Vunkan API
I bought nano NanoPC-T6 based RK3588.
And use Ubuntu 20.04.
My application show error as "vulkan devic not found".
How install vulkan driver for RK3588 on Ubuntu?
    OS: debian
    CPU: RK3588
    GPU: Mali-G610
pi@NanoPC-T6:~/mesa/build$ vulkaninfo --summary
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
VULKANINFO
Vulkan Instance Version: 1.2.162
Instance Extensions: count = 18
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 9
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 1
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Instance Layers: count = 2
VK_LAYER_MESA_device_select Linux device selection layer 1.2.73 version 1
VK_LAYER_MESA_overlay Mesa Overlay layer 1.1.73 version 1
Devices:
GPU0:
apiVersion = 4194306 (1.0.2)
driverVersion = 1 (0x0001)
vendorID = 0x10005
deviceID = 0x0000
deviceType = PHYSICAL_DEVICE_TYPE_CPU
deviceName = llvmpipe (LLVM 11.0.1, 128 bits)
driverID = DRIVER_ID_MESA_LLVMPIPE
driverName = llvmpipe
driverInfo = Mesa 20.3.5 (LLVM 11.0.1)
conformanceVersion = 1.0.0.0
pi@NanoPC-T6:~/mesa/build$ glxinfo -B
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Panfrost (0xffffffff)
Device: Mali-G610 (Panfrost) (0xffffffff)
Version: 23.0.0
Accelerated: yes
Video memory: 15949MB
Unified memory: yes
Preferred profile: compat (0x2)
Max core profile version: 0.0
Max compat profile version: 3.0
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.1
OpenGL vendor string: Panfrost
OpenGL renderer string: Mali-G610 (Panfrost)
OpenGL version string: 3.0 Mesa 23.0.0-devel (git-120202c675)
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 23.0.0-devel (git-120202c675)
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
I can recognize GPU from OpenGL ES3.1, but can not recognize GPU from vulkan API.
Do you have vulkan api driver or firmware?
