Overclocking
I find the M3 to be very very quick. For parallel work in particular. But is it possible to do a bit overclocking?
Because of heat, do not recommend you overclock
I know that it's not recommended, but that was not the question.
By the way, I have mine running with a little custom cooler made of GPU memory coolers at 7 cores between 62°C and 66°C. All without an active cooling. The cooler can be improved, so I think there is much room for potential overclocking.
Anything new about this topic?
I'm finally able to have temps way lower than the throttle temp at full tilt 8-cores. Does anyone have knowledge on overclocking the M3? I have ample power supply to do so for a moderate OC.
No idea about overclocking. What kind of cooling solution did you used?
