HDMI-IN NV12 EDID
Does anybody know how to force the HDMI-IN to NV12?
with this command I can force 422 but not 420
v4l2-ctl --get-edid > edid.txt
v4l2-ctl --set-edid file=edid.txt,format=hex,ycbcr422
any ideas?
Nobody has this problem?
I think it is a hardware-related thing, you can't change to nv12 if the hardware you are connecting from does not support it.
For example, grabbing video from a second board HDMI 1920x1080(out) to HDMI (in) only supports GBR, but grabbing video from my 8K TV set i can have NV12.
I finally managed to use the HDMI-IN with GStreamer. Here’s what I did:
EDID Modification:
First, I removed the YCrCb 444 and 422 formats from the EDID using the Deltacast EDID Tool.
Then, I applied the modified EDID with the following command:
v4l2-ctl --set-edid format=raw,file=hdmiin_edid.bin --fix-edid-checksums
GStreamer Pipeline:
After modifying the EDID, it was possible to use GStreamer with the following pipeline:
gst-launch-1.0 v4l2src device=/dev/video0 ! glupload ! glcolorconvert ! glcolorscale ! video/x-raw(memory:GLMemory), format=RGBA, width=1920, height=1080 ! gldownload ! glimagesink
This setup worked perfectly for me. Hope this helps anyone facing similar issues!
basket random
any ideas?
Forcing the HDMI-IN to NV12 (YUV420) format can be a bit tricky, as it depends on the capabilities of your hardware and the drivers you are using. The command you've used is for setting the EDID to indicate YCbCr422 support. To force NV12, you would typically need to interact with the video capture interface provided by your hardware through tools like v4l2-ctl.
chrisberg wrote:
Nobody has this geometry dash problem?
I also had the same problem :(
EDID Modification:
GStreamer Pipeline:
Was this solution successful for you? I will try.
