Matrix on the NanoPi sync-available problem
I have a NanoPi running some fairly big applications, ie PHP5 and Apache2 and when I do free I have about 5M. I can do a sync-available on this unit.
I want to incorporate the Matrix code, so I am building a system on another NanoPi. This unit has PHP5 but no Apache2. I updated Debian Jessie on it and then tried sync-available. I got this error:
 dpkg: unrecoverable fatal error, aborting: failed to allocate memory: Cannot allocate memory
Doing free shows 1M, so following some on-line advise I did:
echo 1 > /proc/sys/vm/drop_caches
echo 2 > /proc/sys/vm/drop_caches
echo 3 > /proc/sys/vm/drop_caches
This gives me 8-16M, but when I do sync-available I still get the error and free shows 1M.
Can anyone suggest where the problem might be?
Thanks,
Dave
The problem is that /var/cache/apt/archives is too full.
Run:
apt-get autoclean
