nanopi neo: Matrix code possible bug matrix-0.96_128x64_oled
Hi there,
I just built the matrix code because I would like to try the oled functionality it provides. I needed to change the pin numbers from 7 (203) and 11 (0) to 13 (2) and 15 (3) because I already use these pins for other purposes. It builds fine but when I execute the generated module it complains about pin 203 and 0 being occupied already. So it looks like these pins are hardcoded somewhere in the fahw-lib shared object and cannot be changed from code (OLEDInit(pin1,pin2). Please advise.
Thanks in advance.
Djagab wrote:
Hi there,
Thanks in advance.
About how to use the OLED you can refer to FriendlyARM BakeBit wiki part, FriendlyARM launched a new hardware kit which named BakeBit Starter Kit. The kit includes the OLED and provides complete code.
http://www.friendlyarm.com/index.php?ro ... uct_id=168
thank you!
In total there are 28 users online :: 0 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 28 guests
