NanoPC - T6 Full Function Usb-c port
Hi, I am considering to buy a NanoPC-T6. In produck page says that usb full function type-c. I will use a Viewsonic TD1655 Portable monitor which has 65w PD support. Has anyone used as a single cable mode from type-c? can I connect to my portable monitor?
I have used my portable monitor with mine. Works great
You can completely connect it to your phone screen. It works very well with my phone.
I think it is possible, but I am not sure. Because, NanoPC-T6 has a USB-C port that supports DisplayPort (DP), the possibility of connecting to your Viewsonic TD1655 monitor with a single cable is possible. However, to be sure, check the USB-C port details on both NanoPC-T6 and the monitor. If both support DisplayPort and PD, you can use single-cable mode.
You should check the technical information of both devices before purchasing to avoid risks.
