NanoPi-M2 Android LTE or wifi
Is there any information on how to get WIFI or LTE working with NanoPi-M2 on android??
The kitkat img apparently supports both?
Hi
M2 can use USBwifi, you can refer to wiki:
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_M2
Oh, i did not know that you can use that. Thanks that you mentioned that!
chensy wrote:
Hi
how;
Nanopi M2 android OS not work any USB wifi
if works android could you share
but first release android image works usb wifi you know !
but next time friendly arm close this way why ??
and
axp228 work finely when soldering 3.7 batt to boaRD (only nanopi m2)
(when kernel enable this option)
CHARGE OKAY READ voltage AND ALL batt status (linux-android)
but not powering board
and and next AND NEXT time close these padds all boards (now nanopi m2 retired)
Probably a bit late. None of the recent Android builds from FriendlyArm include any support for LTE modems. There are a number of USB options but you would need to build a custom OS.
I've done this but com.android.phone crashes when I get a PPP connection and not tracked this down yet. Looks like a security exception so still digging for this.
I am going to post the Source code for this build after getting permission from FriendlyArm to do so and hopefully someone with AOSP skills can lend a hand to get this working.
