I am trying to install different OSes from an SD card but I keep getting "unknown eMMC" error. It says it is 0 bytes. It worked one out of 15 tries. Is it a power supply issue? It is 5V, 3A.
It sounds like the eMMC might be either corrupted or having intermittent connection issues. Have you tried a different SD card or reflashing the eMMC? Also, check your power supply and cable stability.
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes) Most users ever online was 5265 on Sun Aug 31, 2025 11:40 pm
