It boots on a 128GB card but looks like only has 4GB!
I know it has 8GB on board eMMC but my NanoPi NEO Air will not boot with the SD card out of it. If I plug it in a LED goes on but stays on very dim.
When I put the SD card in it boots but not sure if using the 128GB SD or it's 8GB eMMC.
Here is some commands to show what I did to see all this.
root@FriendlyARM:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 3.6G 924M 2.7G 26% /
devtmpfs 168M 0 168M 0% /dev
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 8.5M 239M 4% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 248M 0 248M 0% /sys/fs/cgroup
root@FriendlyARM:~# fdisk -l
Disk /dev/mmcblk0: 119.1 GiB, 127865454592 bytes, 249737216 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xff95af29
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 49152 131071 81920 40M 83 Linux
/dev/mmcblk0p2 131072 7617185 7486114 3.6G 83 Linux
Disk /dev/mmcblk1: 7.3 GiB, 7818182656 bytes, 15269888 sectors
Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors
root@FriendlyARM:~# resize2fs /dev/mmcblk0p2
resize2fs 1.42.12 (29-Aug-2014)
The filesystem is already 935764 (4k) blocks long. Nothing to do!
root@FriendlyARM:~# resize2fs /dev/mmcblk0p1
resize2fs: Bad magic number in super-block while trying to open /dev/mmcblk0p1
Couldn't find valid filesystem superblock.
root@FriendlyARM:~#
It be nice if could get it to just run off the eMMC and have the SD card as storage.
Any one set it up like that and if so how?
-Raymond Day
Please use the lasted ROM version, it can auto resizing the rest space. Now only BaiduYun Download
-- Mindee
-- Mindee
I guess it wants you to install java and don't want to because it has problems with hacks. So can't download it. But not sure I can't read it.
-Raymond Day
In total there are 41 users online :: 0 registered, 0 hidden and 41 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 41 guests
