build usbtv in NanopPi2
I got the driver in here "https://github.com/mwelchuk/usbtv";
when I type "dkms build -m usbtv -v 1.0"
It just return me error like the following
Error! Your kernel headers for kernel 3.4.39-s5p4418 cannot be found.
Please install the linux-headers-3.4.39-s5p4418 package,
or use the --kernelsourcedir option to tell DKMS where it's located
first you should download the friendlyarm linux-3.4.y from github to your /usr/src directory
Then return back to your driver directory and update the KSRC parameter to /usr/src/linux-3.4.y
now your compilation may be done with no error but this is not the end. you should edit vermagic.h
or utsreleased.h in the kernel source to let the modprobe executes your compiled module. there is
also another solution to run your module with modprobe --force-vermagic.
