NanoPI Neo Air
Hi
I am considering to use NanoPI Neo Air for my next embeded project.
I need some help for my development set up:
1. Plan to use Eclipse for C/C++
2. Develop the code on Linux / Ubuntu in Eclipse IDE
3. And then cross compile for H3 and deploy only the executables onto
NanoPi Neo Air
My questions:
1. I have seen some set up as descripbed above. Where do I get cross
compiler for H3?
2. How can I make my project executable secured in the flash of NanoPi
NeoAir?
3. Also planning to use HD camera with the Neo Air for video, is there any
video camera that I can use with NeoAir?
thanks
Silas
SilasV wrote:
Hi
NanoPi Neo Air
My questions:
compiler for H3?
NeoAir?
thanks
Silas
Hi, Silas
All is here, Please go to the WiKi NanoPi NEO Air's Wiki
-- Mindee
Hi Mindee,
Thanks for your reply :)
I was looking further and I found that Neo Air has 0.5mm pitch 24Pin FPC connector. And I am thinking of using CAM500B 5MP 1080p Camera Module with OV5640 Chip - my question - is the FPC supplied with CAM500B has the same pitch and can be used directly without any problems?
And further I found that Neo Air does not have any HDMI port readily available. And that makes me focus more on NanoPi A64. This has HDMI display port and also DVP camera connector, please let me know if CAM500B can be used with NanoPi A64.
Thanks again for your help!
Regards,
Silas
SilasV wrote:
Hi Mindee,
Regards,
Silas
a. You can use CAM500B on the Air directly without any configure, and the FPC supplied with CAM500B has the same pitch and can be used directly without any problems on the Air.
b. You can use NanoPi M1 has supported the CAM500B and has HDMI display. The A64 now have not supported CAM500B .
thank you!
Hi Jim
Thanks for your reply and information about NanoPi M1
NanoPi M1 looks really nice, only that it does not have WIFI and slow internet. But that should not be any problem.
For now I am going with NanoPi M1 and CAM500b
Silas
