Problems blinking an LED with NanoPi NEO
Hello
I am working with a NanoPi NEO and am trying to flash an LED. I have it connected to pin 23 of the 24-pin connector (through a series resistor), which I believe is GPIOC2. I am using the Bakebit software (Python) and have changed the pin number to '66' in the Python script
led = 66
My led is not blinking. I have tried different port numbers and different pins. I have measured voltage on all pins in the 24-pin connector while the blink script was running to try to find the correct pin but found no luck. I don't have the BakeBit board - could this be the problem? Oddly enough, I did manage to get an OLED display to work using pins 3 and 5 (SDA/SCL).
Any suggestions on what to try next?
thx
This work on my NanoPi Air
http://www.nutdiy.com/2016/11/nanopi-ne ... atrix.html
Install matrix:
git clone https://github.com/friendlyarm/matrix.git
cd matrix
make
make install
Run:
matrix-gpio_out
it Blink LED on Pin7
Thank you. That worked.
RoumenL - thanks but I am using Python.
In total there are 44 users online :: 0 registered, 0 hidden and 44 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 44 guests
