External power button
The button on the PCB is good enough for development work but I want to install this in a case with the LCD so I need to have access to the power button externally.
The schematic shows a connector for this called PWRJ but I can't find this on the board. Does this actually exist?
I could solder wires to the existing switch but that is not the ideal solution.
You cannot external power button on M3 , the hardware doesnot support it.
thank you!
thank you!
Yeah, got a reply from FriendlyArm with the same information.
Real shame as putting this on a daughterboard PCB means I have to solder a wire onto the existing switch so that I can get external access so I can do this from front panel of the enclosure.
You can create an app providing a shutdown / reboot function. Must be signed with the firmware key like described in the SerialPort Demo tutorial.
In Manifest you must request android.permission.SHUTDOWN.
In your code, you add:
Intent intent = new Intent("android.intent.action.ACTION_REQUEST_SHUTDOWN");
intent.putExtra("android.intent.extra.KEY_CONFIRM", false);
intent.setFlags(Intent.FLAG_ACTIVITY_NEW_TASK);
startActivity(intent);
