LibreElec 8.0.1 - Working using Kicker22004 method
Full 1080p playback with x264, tiny jitter on x265 and buck bunny 4k 60fps skip but 30fps plays fine also Deadpool 2160p sample (at 1080p) without any issues.
Download LibreELEC here https://forum.libreelec.tv/thread-2156.html
dd the img to microsd. and then follow Kicker22004 youtube video for fusing.sh
viewtopic.php?f=55&t=619
Suggest using gxbb_p200_2G.dtb for 2Gb of memory as dtb.img, and is available from armbian BOOT img dtb folder.
Yep yep, Also the patch tar now has the 2GB dtb in it!
Dear all
I actually using 8.0.1j version I´ve found out there https://drive.google.com/uc?id=0Bzy4G9j ... t=download and it worked OOTB , but i wanted to update libreelec so I assume this patch will work for libreelec last version 8.2.0.1 doesn´t it?
I´m not very keen on linux, It is any way to patch LE image under windows 10?
I´ll use dtb provided in rar instead of
gxbb_p200_2G_1Gbit.dtb, gxbb_p200_2G_1Gbit_OTG_Port.dtb or gxbb_p200_2G_1Gbit_RealtekWiFi.dtb found on libreelec forum
I´ll try with a linux distro and follow step by step video indications Let´s see if I can do it. :D If I can everybody will!
Thank you for your help
Best regards!
