lvds support
i would like to know if the lvds port is limited to friendlyarm's lcd products or if it can be used as an universal lvds port to connect laptop screens parts for example ?
thank you
Hi our NanoPi 2 doesn't have an LVDS interface.
Did you refer to the NanoPi2's LCD interface? If you referred to the LCD interface I would put it this way: if your LCD's connector matches the our LCD interface's Pin specifications yes your LCD can work with our Pi 2
