Smart210 (Tiny210v2) | S5PV210 latest board Sync issue
Hi All,
Previously we used Tiny210v2 | S5PV210 ARM board (SD card slot below the core board)Image and build a image in windows ce 6.0 using given BSP and loaded into Tiny 210 board and this board is sync to windows pc. We are able to access the falsh memory folder of this board from our windows 7 PC.
Our issue is recently purchased new board Smart210 (Tiny210v2) | S5PV210 (SD card slot near to IO's) Image not sync with windows PC. Is there any software install into my pc to access the nand flash folder ?
Any one reply above thread is appreciated.
Main issue is after loading the windows ce 6.0 how to load the files to Flash memory of the board ? Any software is needed in windows PC ? Could any one help us to resolve the issue.
Thanks in advance.
Yes good that you posted it here
