Which pin(s) are used for PWM?
Number#    Name             Number#    Name
1    SYS_3.3V            2    VDD_5V
3    I2C0_SDA / GPIOA12      4    VDD_5V
5    I2C0_SCL / GPIOA11      6    GND
7    GPIOG11               8    UART1_TX / GPIOG6
9    GND                  10    UART1_RX / GPIOG7
11    SPI1_MOSI/GPIOA15      12    GPIOL11
13    SPI1_MISO/GPIOA16      14    GND
15    SPI1_CLK/GPIOA14      16    SPI1_CS/GPIOA13
17    SYS_3.3V            18    NC
search on the page
http://wiki.friendlyarm.com/wiki/index.php/NanoPi_Duo
for PWM and you will find the following:
Pin silk screen Name Linux gpio
DRX DEBUG_RX(UART_RXD0)/GPIOA5/PWM0 5
I'm using the mini shield. Is it accessible via the 2 x 9 header?
Frank
Does that means it's accessible as DEBUG_RX on the Debug UART port?
If I take a look at the picture
http://wiki.friendlyarm.com/wiki/index. ... i_Duo3.jpg
I personally would think so....but I didnt really know it :(
In the schematic at
http://wiki.friendlyarm.com/wiki/images ... 0_1706.pdf
there are only 2 Pins for PWM:
PA5/UART0_RX/PWM0/PA_EINT5
PWM1/GPIOA6
PS: the Schematic is text-searchable with Ctrl-F :)
By this image:
[img]
http://wiki.friendlyarm.com/wiki/images ... uo_PCB.png
[/img]
I would guess it's the RX pin, but I just don't know, either.
I hope we get an answer. :-)
I confirmed, today, the RX pin on the debug UART is used for PWM by connecting up a servo and using the gpio utility installed on the NanoPi's OS.
I used this tutorial for the Raspberry Pi - figuring that WiringNP on the NanoPi was a variation of WiringPi on the Raspberry Pi. The only variation I think would be that the NanoPi's PWM runs at 24MHz,
https://learn.adafruit.com/adafruits-raspberry-pi-lesson-8-using-a-servo-motor/software
gpio -g mode 5 pwm
gpio pwm-ms
gpio pwmc 240
gpio pwmr 2000
gpio -g pwm 5 100
gpio -g pwm 5 150
gpio -g pwm 5 200
